Can someone post some pics of the hood latch assembly on the hood of a 149 or similar tractor?
I have the springs on the dashboard side, but there is nothing on the bottom the hood for them to grab ahold of. Curious what it looked like originally and what i might be able to fab up. I can't seem to find the actual latch piece listed anywhere.
-Jason Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54 Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks Gravelys 5260 | CI Walk-behind (Project) And a couple of Subarus |
You should also have a hood rest that bolts to the front of the pedestal at the top. It is part no. IH-544188-R1. Supposed to keep the hood from resting on the fiberglass cowl. |
But I think I understand what you are saying. There are 2 holes on each side of my hood. Looks like a rod or something bolted there, but perhaps the spot welds broke and put holes there. Perhaps I could bend up a piece of steel and bolt it in place. I don't have a welder.
Yes those holes do look like they would have been for the spot welds. If you are not concerned about looks I dont see why you couldn't use a piece of threaded rod completely across with a nut inside and outsde on each side. |
Maybe I'll try that first and see how well it works. Something's gotta be better than nothing. Thanks for the input!
