|  | Thread Tools | Display Modes |
|  Couple of 882D Questions
			Does anyone know where I can get a wiring diagram for an 882D? It looks like I'm going to need one!  Also, is there a part number or source that is recommended for the fan belt (Cub Cadet P/N 754-3022) on this engine? I have checked out the usual suppliers I use and it appears to be NLA. Maybe a cross-reference chart somewhere?  This is my first smoker restoration so I'm sure I'll have a bunch of questions for you guys. I do appreciate the help! Steve
				__________________  Steve 149 with #2A Tiller 169 mowing machine 1864 with 3pt hitch & 54" GT deck Haban Sickle Bar DB moldboard plow Brinly #10 plow 1959 DB Suburban with 3pt 882D with 3pt and front remotes - "in progress" |
			what diagram you after and would it be roughly the same as a 1772 diesel? if so I have the manual. let me know
|   Quote:
 The 754-3022 Belt IS available from Cub Cadet
				__________________ [B]Roland Bedell[/B] CC Models: 100, 105, 1450, 782, (2) 784, & 2072 [SIZE="4"][B][COLOR="Red"]Buy:[/COLOR][COLOR="Blue"] Made in the USA[/COLOR][/B] [/SIZE]:American Flag 1: |
			Not sure if they are the same. 1772's came out in 1989 and 882's were 1984. I hope someone can clarify the similarities? I basically need diagrams for everything. This old gal was not taken care of at all! I will let you know when I figure it out though. Thanks! Steve
			Gates belt # Fan = 6727 Water pump = 7320 Good luck and keep us up to date.
				__________________ This ain't no hobby....it's an addiction |
			Thanks Oak, Will do. Gates belts are much easier to procure around these parts than the alternative. Steve
			You'll likely want to replace the water pump while you're in there. Mine ran noticeably cooler after I did the job. The upper radiator hose is NLA. During your restoration, I suggest doing the starter and glow plug upgrades, as well as the add-on heavy gauge ground wire. These machines can get by just fine with a small tractor battery as long as you perform these upgrades.
|   Quote:
 New gear reduction starter arrived today, upper rad hose is coming tomorrow (alternate Kubota part that requires a bit of trimming) complete filter service kit coming from Patton Acres. If you have any good parts sources, I would love to know about them. I can't wait to fire this thing. PO started it up to roll onto the trailer when I picked it up but I want to ensure all is correct before I run it for any length of time. I drained the oil this past weekend and it was like a combination of molasses and Jello!
			If you need Kubota parts these guys have never let me down yet and their prices are the best I can find. http://www.messicks.com/vendor/kubota
