#21
Looks like it needs a deck ..I got you covered ..just $500. plus shipping
Frank __________________ IH 982 , 3 point CCC 782 ----------------------- ![]() |
#22
![]() Quote:
you got it. |
#23
A couple pictures...
982's, 782 JD 318's, 332 & 420 Farmall Cub & Ford 8N |
#24
Missing lots of stuff under there.......
#25
Good for you.
Now the work begins and scrounging for parts to build her back up again. Congrats
Joe 1200 Puller[/U][/B] 1864 2072 with 54 Inch Haban Blade |
#26
![]() methinks he took those off to check for the mouse's nest,that I do believe
#27
We need like a big open mouth suprised emogie. Cuz I would have a hundred on my post. That is super un real. Why such a low figure?
#28
Thanks all. The fuel tank was out when I got it but back in now...the only thing really missing is the ductwork for over & around the muffler. The tractor was fairly clean but had sat outside for a few years, which corroded the original ignition switch. The PO replaced it with the incorrect switch, couldn't get it running, and gave up. He's moving so just wanted to get rid of it.
