Old 08-12-2010, 01:14 PM
Not really. And $12 isn't expensive. Price the cam follower and you'll see what a slightly expensive part is. You won't need to do it again for 30 years, and the best part of all is, you can still get the part.
Old 08-12-2010, 01:22 PM
GrantC GrantC is offline
Question: where can I get them for $12?
I checked one of the site's sponsors, who sells them for $40, and nearly fainted!
-=[ Grant ]=-
Old 08-12-2010, 01:28 PM
The last one I bought from my local Cub Cadet dealer was $11 and some change.
Old 08-12-2010, 02:09 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
Grant,
I believe there were two manufacturers of the steering column. So depending upon the one you have the cover with foam seal can be $42 (left photo) or $11 (right photo). I think the $11 part is more common.
Old 08-12-2010, 03:57 PM
Well, that would explain it! I haven't taken mine out; I sure hope it's the $11 model!
-=[ Grant ]=-
Old 08-12-2010, 05:27 PM
IH only used the Ross Steering Column. The Retainer and Gasket on the RH picture above is the correct parts.
Old 09-14-2010, 08:18 PM
If I'm not mistaken the one on the left is only for Originals none of the other models used that seal and it will not fit in anything other than an Original column. AND IH also sells the one on the right as a replacement for the one on the left, oddly enough the one on the right does fit in an Original column.
Old 12-15-2015, 09:59 AM
mattop mattop is offline
I have the engine out of my 1650 right now to replace a seal, and I'm thinking about doing the steering rebuild, too. I have a great hardware store in my area where I can get the NICE 605 bearing as well as the shim washer and nut. My only problem is I don't have any specs on the shim washer. Can any of you guys tell me the size and thickness of what I need to get? I assume the nut is just a 15/16 nylock?
Old 12-15-2015, 04:43 PM
twoton twoton is offline
..... you'll still need one washer. The one that was originally under the two jam nuts works fine.
I think you can use the one you have.
Old 12-15-2015, 04:45 PM
Ahh, I missed that! Thank you. I was initially confused by your quote from Matt G., because my name is Matt G. as well! I was thinking to myself, "I didn't type that. I know I didn't type that!!" It was the other Matt G!
