Old 05-07-2016, 11:04 AM
Dodge71 Dodge71 is offline
Default 126 Cub Cadet
Hello:
I bought a 126 Cub a few weeks ago. It had a snow plow on it, and mower deck not attached. I had to buy a few small prices to attach mower deck. I was told p.o never had it on in the three years he owned it. I've been trying to mow with it but keeps throwing off PTO belt. Its 81x1/2 .80 and it was too small. Any suggested fix would be a big help. It will mow for half hour or hour till it kicks the belt. But once it kicks it off keeps coming off every couple minutes.
Old 05-07-2016, 02:53 PM
Welcome to OCC
Pictures would help a lot in fixing your problem. A picture from the side of the mower deck showing both the deck and the belt angle in relation to the deck pulley and one from the front showing the mule drive ( that's the part that turns the belt 90 degrees to run to the mower deck from the engine)
It may be as simple as the front of the mower deck being adjusted too low.
Are you using a Cub Cadet belt? ( any number visible on it? )
Jeff
Old 05-08-2016, 09:18 AM
Lanceskene's Avatar
Lanceskene Lanceskene is offline
Welcome to OCC Dodge71, sry I cant offer much help, I just picked up a 126 myself but havent started working on it just yet. Hope to see some pics of yours tho in the near future
Lance / Alberta Can
IH 127 w/deck, snowblade
IH 154 Loboy(x2) w/creeper 3pt and 3160 deck
CCC 12.5 w/deck
Plus 35 or so non IH tractors
Old 05-08-2016, 12:05 PM
Welcome to OCC! Congrats on your 126.
Old 05-14-2016, 08:05 AM
OK I'll try to get picks I did not have a cub belt on it. I bought a cheap one to see if mower deck actually worked . I have noticed a spring missing on the mule drive. When I bought this cub it only had the snow plow on it . po said he never had the deck on it.I been buying parts as I find them for it
Old 05-14-2016, 12:07 PM
Yeah, if the spring on the mule is missing that's a good place to start.
There are good instructions for adjusting the mule in your owners manual.
Old 05-14-2016, 12:48 PM
I don't have a owners manual
Old 05-14-2016, 05:16 PM
Here you go Dodge
http://www.onlycubcadets.net/forum/s...ead.php?t=4664
Mods the belt chart in technical library is mucked up. Just wanted to let you know
Old 05-16-2016, 09:11 AM
Thank you gentlemen I put on a cub belt and it hasn't messed up so far. Guess the materials are not the same.
