Old 05-01-2016, 10:43 PM
farmall fred's Avatar
farmall fred farmall fred is offline
Default NF hydro lift belt
I just about have my hydro lift restored for my 100. Just wondering if any body has a belt number for it or the size. I was hoping to get one from NAPA.
Thanks
Tom
Old 05-01-2016, 10:50 PM
I would highly recommend spending a few more dollars and using a genuine Cub Cadet belt due to the amount of work involved to change the belt.
Old 05-01-2016, 11:27 PM
https://www.google.com/url?sa=t&sour...SmM77Y5kcLSdPQ
this will tell you the length but I agree with Jeff.
Old 05-01-2016, 11:31 PM
That's a handy link. I saved it!
Old 05-02-2016, 08:58 AM
Thanks for the link to the guide. I found the correct part number, 386160R1, 3/8 X 33 long. I will pick one up at Napa today. I have no issues running Napa belts on our farm tractors for the fan, water pumps and ac compressors so I am not worried about using one for this hydro pump. I will not use a aftermarket belt for a mower drive belt that has to go around a mule drive.
Later
Tom
Old 05-02-2016, 10:33 PM
Dad mentioned once about those NF hydro units at the shop he worked in someone would wire up another belt in the area (somehow) so if/when the hydro belt took a dump it'd be easier to replace than pulling the engine/rear end.
Old 05-02-2016, 10:50 PM
Good idea but I don't think I will have to replace the belt for a long time. The 100 does not get a lot hours in a year. It mainly is used to till the garden and also I mount a sprayer tank on it to spray the yard and around the buildings. I also scored a IH front blade that will work on it so it may get used some to grade the driveway.
Later
Tom
Old 06-05-2016, 12:03 PM
I finished the Hydro lift for the 100 a few weeks ago but got busy with farming and never took the time to post some pictures. I had a chance to use it when I tilled the garden and it is great not having to lift that heavy tiller by hand any more. I should have put this on years ago when I first bought it. Here are a couple of pictures.
I rebuilt hyd cyl with new piston, shaft and seals. also resealed hyd pump.
Primered and ready for paint
Painted with Federal yellow with Valspar hardener.
pump and lift installed, Hood and grill next.
Old 06-05-2016, 03:40 PM
Rmowl's Avatar
Rmowl Rmowl is offline
Wow that looks great there Tom! Nice to see going the extra mile and doing a good job putting it back together, sweet!
-Rick
IH 782
IH 126
CCC 1863
Old 06-05-2016, 09:17 PM
Thanks, As I stated I wish I had installed the pump years ago when I first bought it. It was in very rough condition and I got discouraged when I tore it down so I boxed it up and kind of forgot about it. It sure makes operating the tiller easier. I restored the 100 about 15 years ago and I polished up the paint when I installed the hydro unit and I was surprised how well the paint still looks. It is IH Federal yellow and IH 935 white with hardener.
Later
Tom
