Old 04-24-2016, 10:46 PM
But you should set the timing never the less...
Just the way the link says.
Agreed!
Yep. Setting the governor is pretty simple! That's all there is.
Old 04-25-2016, 05:55 AM
Flingarrows's Avatar
Flingarrows Flingarrows is offline
Thanks again all
Old 05-01-2016, 07:11 PM
I got the governor set, new points, set timing, new plug and air filter.
It is still surging. Maybe that is not a good description of it. It pulls strong for about 4 seconds, the seems like it is running out of fuel, then recovers, and does it again.
I am thinking the carb would be the next thing to check. Maybe some dirt in it.
Old 05-01-2016, 07:21 PM
Billy-O's Avatar
Billy-O Billy-O is online now
Yup! Try richen up the fuel/air mixture a little bit and see what happens.....though I'd still pull and clean the carb.
Plow blade
#2 Cart
QA36 snowthower
Old 05-01-2016, 07:37 PM
Thanks Billy. I adjusted it almost 5 turn out from the original 2. It helped a bit, but not nearly enough. I think next Sat I'll be taking it apart, and blowing everything out.
This is one of those $30 ebay carbs, so hopefully the quality is not an issue. I still have the walbro that came on the 105 when I got it, but not sure if rebuilding that would be a better option or not.
Old 05-01-2016, 10:43 PM
Sounds like the main jet is plugged, or the orifice isn't large enough. 5 turns out, you just as well remove the screw. It goes max fuel at around 3/3.5.
Old 05-02-2016, 07:27 AM
Thanks, I noticed that there was really no improvement when I got it out that far.
On a good note, it is all tuned up. I had been meaning to do that since I got it
Old 05-02-2016, 07:46 AM
TN_Explorer TN_Explorer is offline
Since attacking the engine has not seemed to help . . .
Have you checked the deck? I had a similar problem and it turned out to be a binding bearing in the deck putting a heavy load on the system.
Just a thought.
Good luck & let us know what it was when you get it sorted out.
Old 05-02-2016, 07:53 AM
Just a thought.
Likewise, check the tension on your mule drive belt, as well.
Old 05-02-2016, 08:07 AM
I just put a newer spindle on the center of the deck before putting on for the season. The others seemed to move ok, but I will recheck. I did grease them all as well
On the mule drive, can the tension be set too tight?
