Old 04-24-2016, 09:19 AM
2016efi 2016efi is offline
Default 2016 cub - EFI engine surging
Hi like I said the 547cc efi engine is surging when started at full throttle at low throttle it's fine when pto is engaged it's fine no idea why a brand new mower would do this. I called dealer I purchased from they said it's part of break in process and put a few hours on it and if it's still doing it they will come pick it up... I don't believe that since my dad bought same mower and his doesn't do that. What should I do? Thanks
Old 04-24-2016, 09:44 AM
Is it possible the fuel is old or has water in it? As long as it's under warranty I'd just do what the dealer says and put a few hours on it and go from there, regardless of what we say the dealer probably won't do anything for you until you try what they said.
Old 04-24-2016, 09:52 AM
cyr2872's Avatar
cyr2872 cyr2872 is offline
Surging is not part of a break in procedure. If it's under warranty the dealership needs to fix it or provide a solution other than 'oh, it's part of the break-in.' First thing I would think it was would be fuel pressure. EFIs needs proper fuel pressure at all speeds for the injectors to open/operate. Quick check of the spark plugs and air filter would be good too. Beyond that, they need to fix it.
FYI, my EFI performed amazing from first crank.
- Jason
________________________________
1872 - Kohler 28hp EFI repower
Old 04-24-2016, 10:27 AM
What model tractor are you dealing with?
Old 04-24-2016, 10:34 AM
Hi it's a 2016 xt2 Enduro 547cc efi
Old 04-24-2016, 10:58 AM
OK and what engine do you have? Kawasaki or Kohler?
Old 04-24-2016, 11:01 AM
Why do you start it at full throttle? Do you start your car at full throttle?
Old 04-24-2016, 11:19 AM
It's a cub engine not kawasaki or Kohler and I don't start my car in full throttle obviously I do what Manual states which says start in full throttle
Old 04-24-2016, 11:34 AM
Cub doesn't make engines. It's either a Kohler or Kawasaki.
I highly doubt the manual says to start at full throttle. Even if it does, stop it!! It's not good for it.
Get the dealer to make it right. No one here is going to be able to help on an EFI motor. They are computer controlled, and you have no way to read the information it is getting. Get it back to the dealer.
Old 04-24-2016, 11:48 AM
I just spent about a 1/2 hour trying to find out who makes that engine and came up blank. What ever it is it's a vertical shaft single with injection and it's branded Cub Cadet.
