Old 04-11-2016, 06:11 PM
Default Quality time with the 108
I pulled the 108 out of winter storage today to get it ready for PA plow day this weekend, I was thinking it would be a quick oil change and adjust the brakes but it turned into a bit more. I noticed the head gasket was leaking so I pulled the head and decided to pull the valves and clean them while I was there, I used my patented paint stick valve removal method and had the valves out and in in about 10 minutes. I will need to pick up a head gasket tomorrow so I'm going to take the head home and true it on my glass workbench while I watch Street outlaws, I was pretty surprised how clean the fins were when I pulled the tins. I'm going to clean the carb while I'm at it since it seemed to run weird today, I had to keep choking it to get it to the garage. Once the engine is back together I just need to adjust the brakes and it will be ready to plow, I guess I can't complain since I've owned this tractor 5 years and this is the first time I've touched the engine or carb.
Old 04-11-2016, 06:21 PM
Nice Tim. Glad you did it now than day of like I do. I'm in the beginning of my 108 resto so thanks for the pics I'm needing some inspiration, looks great.
Old 04-11-2016, 06:53 PM
I tore the carb apart, it had some jelly in the bowl and the plastic float was half filled with gas but I had one sitting here so its cleaned and back together. I bead blasted the head so its ready for me to true tonight.
Old 04-11-2016, 06:58 PM
Your head looks very nice Tim,are you going to use new bolts and thick washers?
Old 04-11-2016, 07:08 PM
It has studs with a nut then a long spacer and then another nut, I think I'm going to replace them all with bolts except for the two that the heat shield attaches to.
Old 04-11-2016, 07:13 PM
Looking real good Tim, nice work.
Old 04-11-2016, 07:46 PM
you will still need the thick washers though, and the other shield will need spacers also....
Old 04-11-2016, 07:53 PM
longislandcubs longislandcubs is offline
Thumbs up
That is a very good looking 108, one of the cleanest I have seen.
Old 04-11-2016, 11:04 PM
The head was pretty bad but I got it all straightened up.
Old 04-11-2016, 11:06 PM
Hand sanding heads makes me tired. Your a body man though, so you should be used to wax-on, wax-off.
