Old 04-11-2016, 03:31 PM
kuleinc's Avatar
kuleinc kuleinc is offline
Thanks for the tip!
Anybody have any tips on getting my metal fan off my old drive shaft? I've loosened the obvious set screws but it will not budge and I'm afraid of hitting it too hard with drift and hammer... and breaking fan or deforming it in someway...
Check out our videos and our instagram!
1967 Cub Cadet 123 and 122 | 1987 Vanagon Westy with 1.8T engine | 1986 John Deere 330 | 2007 Yamaha Grizzly 450 | 2007 Yamaha Wolverine 450 | 1996 Yamaha Blaster | 1988 Kawasaki JS440 | 1991 Yamaha Super Jet | 2006 Kawasaki STX-15F
Old 04-11-2016, 08:11 PM
Originally Posted by kuleinc View Post
Thanks for the tip!
Since your old driveshaft is shot, I would saw the end off close to the fan. ( flange end) Remove all burrs with a file and slide a piece of close fitting pipe or tubing over the long end of the driveshaft. A bolt on the sawed end to allow the fan to slide off and tap the pipe to drive the fan off.
Old 04-11-2016, 10:21 PM
kuleinc's Avatar
Thanks Jeff, I'll try to cut it up tomorrow...
Old 04-12-2016, 01:13 PM
kuleinc's Avatar
Thanks Jeff, That worked out very nicely! It slides right on your replacement shaft. My yellow paint came in today, so I will try to paint the parts today and tomorrow so I can install them this weekend.
Old 04-12-2016, 09:07 PM
Glad to hear it worked well
Don't paint the end of the driveshaft where it slips into the hub. I don't make it with "paint clearance".
Old 04-12-2016, 09:20 PM
kuleinc's Avatar
Oops
Old 04-12-2016, 09:24 PM
Oops
( just kidding )
Old 04-18-2016, 12:47 AM
kuleinc's Avatar
My brake plunger is leaking and needs a new oring, how do I get the brake arm out? It's stuck between two pieces of metal that do not move from the frame?
Old 04-19-2016, 11:24 PM
kuleinc's Avatar
I was putting my tractor back together, and I think I did something stupid. I forgot to press the pin in the end of the driveshaft for the engine do I need to split my tractor to put the pin in or can I just try to pound it in with a hammer in place?
I ask because someone warned me to support the end of the hydro when pinning the flex disc couple on it...
Old 04-20-2016, 07:33 AM
ironman's Avatar
ironman ironman is offline
The part in this picture labled "pivot pin" goes through the hole in the part labled "brake lever". The part labled "adjusting screw" must be completely taken out. When it is in, it goes through the groove in the pivot pin and keeps the pivot pin from coming out. Alot of rust may have formed on the pivot pin, so soak it real good with penetrating oil before trying to tap it out. The part in the picture labled "retainer" is where your "O" ring is. Once you get all the external parts off nothing holds it in but it can be a bitcz to get out. Once again lots of penetrating oil and prying.
