![]() Quote:
got the ole girl running pretty good. When I say a heavy spring the govenor arm could not move heavy enough to close the screen door type..
The tractor came with a homemade blade on it needs some mod to work properly.. I was really suprised with the power the 123 has I used it to grade my drive way yesterday all I can say is that it really impressed me. thanks Tim |
Better make sure the governor has the right spring on it. You say you removed it..... you did leave a spring on it though right?? IT HAS TO HAVE A SPRING. Better adjust the governor and make sure the high-idle, no-load is set right. Should be 3600 RPM... up to 3800 is acceptable.
Yep has the correct spring on it now have an older gentelman that all he has ever done is work on small engines and he helped me with the correct spring. engine is purring now. Few more things to fix up on the machine and then strip it all down and give it a new paint job. Wires are in poor condition from setting out side for a large part of it life.
If the wiring is bad Mlamar makes great replacement harness's
http://www.onlycubcadets.net/forum/s...ad.php?t=34457
