Old 03-07-2016, 09:08 AM
MrSam
Guest
Posts: n/a
Default Tiller Compatibility
I have a 122 Cub and want to know what tiller models will work for my NF tractor. I see #1 and #2 mentioned a lot, but don't know the difference or if they will both work. Also, any special parts I need to get for mounting and using the tiller? Here's what I know (so far) is required to hook up and run:
  • Creeper Gear
  • Tiller
  • Short Belt
  • Long Belt
  • PTO Gear Box
  • Tiller Brackets for Mounting
Old 03-07-2016, 10:12 AM
There were 3 tillers available for our Cubs a #1, #1a and #2.
Quite frankly I don't know the actual difference between a #1 and a #1a. I'm guessing the difference was the mule drive (bolt on or quick attach) someone will be along shortly to confirm or debunk this.
The #1 and #1a tillers had a 26" cutting width, with 6" extensions available that could be added to one or both sides giving you a 32" or 38" cut. The #2 tiller had a 38" cutting width.
In any event, any of the 3 will work fine with your 122. Even if your tiller comes with the Q/A mule drive, it will bolt to the existing holes in the front of your tractor frame.
The only things that I see missing from your list, is a 3 point hitch and the correct lift pin are also required to raise and lower the tiller.
I also suggest a spring assist or hydraulic lift, to help raise and lower the tiller, because they are HEAVY!
If you have a use for a tiller, you will never regret getting one, they do a fantastic job and really are great fun to use.
