We got forcast for 4-8" of snow last night. I checked the tractor and snow thrower over and when to Lowe's for a 48" rod to make a handle for the rotator. Once installed, the chute didn't rotate. It had the shorter length gear on it. I got the gear off the QA-42, it's longer, and it rotates slighty. I can rotate the chute by turning the u-joint without the handle. Looks like the gear is cockeyed, but I don't see a way to adjust it. other than a BFH. What am I missing here?
Papaw 1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
BFH....sounds like the remedy to me.
i thought the same thing, but that's my standard fix if duct tape don't work.
It does look like the bracket is bent a little, ya might try bending it back with a big pair of pliers or a crescent wrench.
Thank you sir!
Now take the rotator off the bracket and either hit or bend the mounting bracket with a wrench as mentioned.
otherwise you will break the rotator, if left on while bending. They are thin die casting. Be careful, you've been warned.
Exactly right, take the chute adjuster off first!
Will do! If it breaks, is it a Duct Tape fix?
Got it for now. Took a Harbor Feight tarp clamp apart & cut it dowm for a shim.Now to buy one of those hi dollar u-joints.
