Old 12-29-2015, 03:12 PM
zimm17's Avatar
zimm17 zimm17 is offline
Default Need a custom made linkage rod- can anyone point me the right direction?
The lift rod on my 60's sears snow blade is not the right length and I'm hoping to find a source to get a 9/16" in diameter steel rod, with ends bent away from each other (S-shape?) and 9" length from center to center of each end. Can anyone help? I tried shortening the one I have but no way in heck can I bend that rod 90 even with a vice, torch, and big hammer.
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 12-29-2015, 04:00 PM
Try Jeff in Pa
Old 12-29-2015, 04:03 PM
zimm17's Avatar
Ha, he fixed my snow blower pulley.
I also might just do a threaded turnbuckle body with ball ends- then bolt it to the blade lift. Then it'll be adjustable and cost will be about $30 in parts.
1973 Cub Cadet 149
Old 12-29-2015, 05:00 PM
twoton twoton is offline
like this...
http://www.onlycubcadets.net/forum/s...3&postcount=52
Old 12-29-2015, 05:07 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
If you have one that is too long, how about cutting out the extra in the middle and welding it back together?
Old 12-29-2015, 05:12 PM
zimm17's Avatar
Originally Posted by twoton View Post
That'll be perfect if it's 9" long. I'll send him a note.
Ehhhhh.... I don't trust my mig skills that much :-)
1973 Cub Cadet 149
Old 01-05-2016, 07:01 AM
zimm17's Avatar
Thanks Jeff! Price was great too.
1973 Cub Cadet 149
Old 01-05-2016, 10:37 AM
cub123's Avatar
cub123 cub123 is offline
That should work! Those sears blades are bad for the linkage wearing out and only lifting and inch off the ground, I have one that does that.
Old 01-07-2016, 05:11 PM
zimm17's Avatar
I hope so. Once I get the length right, I'm going to tighten it down and powder coat or paint it.
1973 Cub Cadet 149
