The PO of my 682 wired a push button starter button because he said the iginition switch was bad. Well after some playing, I found out the switch is not getting the proper power. So either there is a bad wire or another problem.
The electrical diagram I have shows two saftey switches, one being the pto seat switch. Can anyone tell me where the 2nd switch is and what it does? |
Its probably the neutral safety switch...brakes gotta be depressed for it to start... (try that first) Just follow your brake pedal connections. If i remember, mine is located center of the tractor between the frame, you might be able to see it with the tunnel cover off.
metalrain |
