Old 11-25-2015, 06:44 PM
sbd-3's Avatar
sbd-3 sbd-3 is offline
Default Winter Oil
This is my first winter with the cubs.....Can i run 5W30 oil in them?????
Jerry
72,106,107x2,125,126,127x2,147x2,149x2,1200
Old 11-25-2015, 07:36 PM
What engine are you running.....???
Old 11-25-2015, 07:43 PM
sbd-3's Avatar
Default Winter Oil
Sorry went brain dead...Kohler...3 12s all singles... The Cubs are a 125,126,and a 127
Jerry
Old 11-25-2015, 08:18 PM
Terry C's Avatar
Terry C Terry C is offline
I am no expert cause I only run my 149 in the winter. In it I use
Kohler 10w30 oil. Change it out to 30 when days are consistently above 40-45 deg
The lighter oil really helps the starting in the cold.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 11-25-2015, 08:50 PM
This question arises often and always gets varied responses. That is why it is described in the Technical Section of the Forum (under Tractors). You should reference that to seek a response to your question. Not trying to be short with you, but trying to help you become more familiar with the forum and more resourceful.
Keep in mind that the 125 and 127 are hydrostats, so cold starts are more difficult as the hydraulic fluid is thicker viscosity. However, some guys have heated garages/storage facilities or they run heated magnets on the bottom of their rear end of their cubs. I run 10w30 pure synthetic in my cubs and never had any problems with engines.
The 126 should start up a lot easier since it is a geardrive.
Drive safely, eh!
Old 11-25-2015, 08:55 PM
jimbob200521's Avatar
30wt Sgell Shell Rotella year round in my Cubs, no heated garage or block heaters. Start, give it 10 or so to warm up and get to work!
-Ryan
Old 11-25-2015, 09:09 PM
sbd-3's Avatar
Default Sorry
Sorry i didn't think to look there....Mods can you delete this thread so no more times wasted on it..THANKS for the replys guys
Jerry
Old 11-25-2015, 09:17 PM
olds45512 olds45512 is online now
its the internet, im pretty sure we're all here to waste time.
Old 11-25-2015, 10:22 PM
Shotgun Wedding's Avatar
Shotgun Wedding Shotgun Wedding is offline
I would put money on that this is NOT a recommended winter oil choice.
In temps dropping below 32F, SAE30 is not going to be a good choice. Don't take my word on, ask Mr Google to ask Mr Kohler.
10W30 or 5w30 is the winter oils of choice.
Old 11-25-2015, 11:21 PM
Terry C's Avatar
It's too late now cause the debate has started, right after this post I'm going to start a thread on how hydros are better than gear drives.
Terry
3225
