Old 11-25-2015, 11:48 AM
dcooke570 dcooke570 is offline
Originally Posted by ccr147 View Post
I like the elift but the worst thing is fixing them when they break. I put new bearings, bushing, brushes in the motor on mine then the spiroid gear went. I haven't fixed it yet as I'm contemplating selling it and putting a winch on the tractor to raise and lower implements.
Curt
Curt,
Mind if I ask what brand your actuator is? What's the poundage your actuator is rated at? What type of implements are you lifting?
This is the one I'm contemplating using:
http://www.surpluscenter.com/Brands/...R-5-1680-6.axd
Old 11-25-2015, 12:22 PM
jkier's Avatar
jkier jkier is offline
http://www.surpluscenter.com/Brands/...R-5-1679-6.axd
I use this one. Lifts a #1 tiller and 36" snowblower with ease
106 Needs a clutch-------107 (Lent to my brother)
123 w/hydro lift & qa36--126 w/creeper and lift
127 restored--------------129 50" mowin machine
129 w/hydro lift-----------147 plow horse w/tiller
149 auction score---------782 KT17SII
Old 11-25-2015, 01:32 PM
Wow, only 500 lbs. We used a spring scale for weighing deer and attached it to the top of the lift arm just below the push button and measured 245 lbs to get it off the ground... at the top of the handle! I can't imagine (or figure out) what the force would be at the bottom of the handle where the actuator would be connected.
Old 11-25-2015, 03:49 PM
jkier's Avatar
Not sure I follow how you were measuring the force but I'm pretty sure the factory electric lift was rated much less than 500lbs and handled the job.
Heres a link to my setup
http://www.onlycubcadets.net/forum/s...9&postcount=12
Old 11-25-2015, 09:27 PM
Thanks for your setup info.
Below is the scale I am referring to. My 104 was not setup originally for an electric lift like your 147, so I have a lift handle to deal with. So we put one end of the deer scale where your hand would go on the lift handle and pulled on the other end horizontally until the box scraper came off the ground to get an estimate of how much force is needed at the top of the lift handle. I can't imagine how much more it must be at the bottom of the lift handle where the actuator would connect up like Vart04 did with his setup: http://onlycubcadets.net/forum/showt...ferrerid=14173
Old 11-26-2015, 01:53 PM
ccr147 ccr147 is offline
Mine is the oem lift. I don't remember what the specs are on the stock lift.
Curt
Curt,
