Old 11-23-2015, 07:08 PM
MWShaw's Avatar
MWShaw MWShaw is offline
Sam,
I need the overall length for that adapter with the spline welded in.
MWShaw
I'll order splined couplers and get one to you asap.
Sorry about the mix up.
Jeff
Thanks Jeff! And Sam!
I really do appreciate all the help, getting this old Cub sorted out.
Old 11-23-2015, 07:12 PM
Well I hope Jeff see's this post?
I will admit, looking back at the pictures of Cub123's install, I was thinking I would be getting (2) pieces from Jeff. But I figured you guy's had been down this road a few times, and knew better than I, what was required?
Do you have the Kubota engine adapter?
Jeff
Old 11-23-2015, 07:24 PM
MWShaw's Avatar
Jeff
I do not believe so?
I have a complete 1772, with the drive shaft it was born with (rag joints and noisy clutch).
I have a CV style drive shaft from a 1864.
I need whatever it takes to hook the 1864 drive shaft, to the Kubota engine and Cub rear end / hydro.
The picture Sam posted, of (2) pcs, is what I believe I need?
Old 11-23-2015, 07:31 PM
There is an adapter for the Kubota engine which uses three countersunk screws to adapter to the four bolts for the CV style driveshaft.
The other adapter is the splined adapter for the rear.
Check out Cub123 post near the top of page 9. ( post 83 ) It shows both adapters.
I'll start on the engine adapter for you.
Jeff
Old 11-23-2015, 07:56 PM
JLM78 JLM78 is offline
Jeff
what the Adapters cost ?
Old 11-23-2015, 08:07 PM
The splined one will be $75 plus shipping and I need to get material to price out the Kubota engine adapter.
Old 11-23-2015, 10:32 PM
Can you make the Splined end
Old 11-23-2015, 10:57 PM
I just purchased a few 5/8" 9 spline couplers tonight so I could make that pictured item.
Old 11-24-2015, 08:57 AM
Jeff
That is the spline for a rear PTO and it is a different size than the input.
Old 11-24-2015, 09:14 AM
Surplus Center has them too. http://www.surpluscenter.com/Power-T...ING-1-2985.axd
They are a 3/4 x 11 spline coupler that is bored out to 7/8 on one side and also has a hole for a pin but I don't remember the size of the pin.
