the lift on this 1811 seems kinda slow and i was wondering if there's a way to adjust the pressure to speed things up? before someone suggests it i already replace the filter and fluid.
This is assuming you have the correct fluid and filter, you can adjust the "charge pump" relief spring. It is item #2 in the image. It can be shimmed to either add or decrease pressure. The procedure is outlined in numerous Hydro Service Manuals.
thank you Roland, i should have thought of that myself.
You do need the shims though.Where do you get them from?
I made one.
you did? what did you use?
I'm sure not everyone will approve but I cut the head off an 8-32 pan head machine screw.
Oh ,if it is okay to do that.
Did it improve your speed? BTW I do have shims....
Yes the plow lifts better now, its still not great so I'm gonna bring a gauge home And see what psi its running. It seemed to help speed up reverse also.
Pressure has no effect on speed. Only flow. I imagine your pressure was fine and you have another issue.
