Old 10-20-2015, 07:09 PM
coinman66 coinman66 is offline
Default Cub 71 wiring question.
Got a 2 prong push button and a 2 prong toggle kill switch. Want to use these instead of ignition switch. How do I wire to start? From the harness I have a orange w black stipe and orange a black and a gray one, and a large diameter red one. I think the gray goes to top post on solenoid and the large red goes to bottom post on solenoid.the 2 orange are for the safety switch which I do not have. Need to know how to wire to solenoid and to push button and toggle please.
Thank u.
Old 10-20-2015, 07:30 PM
cubby102's Avatar
cubby102 cubby102 is offline
Go in the tech section here on the site and download the service manual. There is a wiring diagram in it to help you sort it out
Old 10-20-2015, 07:37 PM
Got wiring diagrams. But that's for the correct way with a ignition switch. I'm no electrician, for sure lol.
Old 10-20-2015, 07:43 PM
cubby102's Avatar
Ok take your constant hot wire run it into the toggle switch. From there you need one hot wire to go to the coil. Also take a wire from the output of the toggle to the push button. From there to small prong on the solinoid
If wired this way the tractor will not crank over with the switch turned off.
Old 10-20-2015, 07:45 PM
cubby102's Avatar
Im at work so i cant look at the diagram to tell you for sure which wire does what.
Old 10-20-2015, 08:21 PM
Ok thanks. Let me know later when u can tell me what color wire goes where.
Old 10-20-2015, 11:20 PM
Originally Posted by coinman66 View Post
Got a 2 prong bush button and a 2 prong toggle kill switch. Want to use these instead of ignition switch.
Why do you want to do this?
Old 10-20-2015, 11:27 PM
Don't have an ignition switch right now. just want to get tractor running to check everything out before I tear down and restore it.
Old 10-20-2015, 11:30 PM
cubby102's Avatar
You could make a very simple jumper harness just to see how it runs. Take a positive wire from the positive side of the battery. And hook that to your toggle and push button. Run the other wire from the toggle to the coil. Then run the wire from your push button to small prong on the solenoid. That way you wont have to mangle the stock harness or make any permanent changes to the machine. ( you can also do this without the button or switch). Where in Illinois are you? I may have a ignition switch I can loan.
Old 10-21-2015, 08:30 AM
Wiring harness is mangled anyhow. I live 20 miles north of Danville, Illinois.
