Old 10-01-2015, 08:54 PM
Mpope03 Mpope03 is offline
Default Launch Failure
I started rebuilding a 1650 in October of last year. I took it completely apart, sand-blasted everything, acid washed, epoxy primer, cub cadet paints, new hardware, and replaced everything that was worn. Tonight I finished the re-assembly and started it up. I drove it for about a minute, tested forward and reverse, and the drive shaft started to wobble at the rear end. It jumped around and broke the blades off my new plastic fan and poked a hole in a hydraulic tube. I shut it down to check it out and fluid started coming from the pump shaft input. I grabbed the shaft and I can move the input shaft to pump around. You can probably understand that I am really unhappy right now. So what this this sound like to you folks - a pump seal? a total pump rebuild? or just go on eBay and buy a used one?
Thanks for your help.
Mike
1978 1250 - in pieces
1976 1650 - running and pulling
Old 10-01-2015, 08:56 PM
Sorry to hear about the damage. It sounds like the bearing gave up. It may be cheaper and quicker to get another hydro unit.
Jeff
Old 10-02-2015, 09:47 AM
zimm17's Avatar
zimm17 zimm17 is offline
Bummer! Keep us posted. When I get out of work today I'm going to adjust the speed control cams in my 149. I started it up after a full rebuild and it nearly pinned me into the garage wall! I pushed the brake to stop, but that put it further into reverse! I got the ignition shut down before any damage though.
Note to self, jack up the rear end before starting any hydro after having it apart...
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 10-02-2015, 11:02 AM
sawdustdad's Avatar
I'd pull the hydro, and disassemble. There are two roller bearings, one in the charge pump cover, the other in the hydro cover. Looks easy enough to knock out and replace (though I've never had to do that).
