Old 10-01-2015, 10:12 AM
kyleb179 kyleb179 is offline
I don't personally have experience with that paint system, however for a little more cash, you can buy this compressor:
http://www.harborfreight.com/air-too...sor-67847.html
and this paint gun:
http://www.harborfreight.com/air-too...spray-gun.html
this is the combo that i use to paint. the compressor keeps up just fine with this gun, you can adjust the pressure output right off the tank, or get an in- line one and attach it to the butt of the gun. The spray pattern was a bit off at first when i used it, so i got the cheapest primer i could find and started spraying all of my scrap steel that i had laying around until i got it to flow how i wanted.
for a 14$ paint gun, it's pretty hard to beat. And at the end of the day, you will have a decent air compressor and a paint gun. (I run a 1/2 impact off this compressor as well) no problem.
just my thoughts.
Old 10-02-2015, 12:08 AM
For the first question you asked about what to all take off the tractor to paint. That depends how detailed you want it, up to you. I've seen it done with most of the tractor together and I've seen them tore down to each piece separated from the tractor.
Your question about paint. As Tim (Olds) said the IH paint is very user friendly, and myself being a first time enamel painter, it worked very well.
I had my white (901) mixed because it's not available premixed and it's the Omni and was $34 a quart and when I needed one more they charged me $26 for another quart.
Old 10-19-2015, 10:35 AM
TripleThreat TripleThreat is offline
http://youtu.be/Y4JwRv90Ekk
Ok I finally was able to get a video of the Northern Tool sandblasting kit for the pressure washer. I used a 2800psi Ryobi pressure washer and it did really good job. My only complaint about the set up is the sand would come out and bursts and not a steady stream I may get an inline valve to try to make the sand come out slower and in a stream and not clumps but it did a good job. If you have any questions just ask and I'll try to answer them.
My vision is yellow
My blood is white
I think something isn't right....
Oh it's cub fever.
Cub Cadet 124
http://www.onlycubcadets.net/forum/s...702#post332702
Old 10-19-2015, 02:11 PM
I have one of those sand blasters. I use it with a 3 GPM 3500 PSI washer. I've found that it likes decent sand blasting sand with out a lot of fine material. I'll try to get you the brand and grade. I also use a 5 gal bucket that I cut the bottom out of and fit a large funnel into it to create a hopper. Other tip is to turn the nozzle so that the suction hose is on top. If water gets into the suction hose for the sand it tends to plug up. It also eats the nozzles. That reminds me I need to order a couple of them.
This is the thread I started some time ago about the sandblaster. http://www.onlycubcadets.net/forum/s...ad.php?t=18016
Pics are how I have my blaster setup and the sand I use. The sand is what Sterling calls #45. I plan on trying the next grade coarser, #25.
Old 10-19-2015, 11:16 PM
mobermiller's Avatar
mobermiller mobermiller is offline
It looks like your blasting through 3 layers of paint. Not bad at all considering the thickness your blasting through. How quick does the metal start to rust after blasting? Thanks for the video!
1961 4 digit serial #9643 Original Custom Restoration
1976 1650 dual stick
1989 2072 374 Haban Deck
2001 3240 60" Deck
2A Tiller
Old 10-20-2015, 07:43 AM
It gets a surface rusty color immediately after you get done but I bet if you wiped it down after to sandblast with paint thinner or something it wouldn't get surface rust on it. I'm very impressed on how good it worked out. Its actually going through 4 layers of paint Blue, Gray, Yellow, and Red. I used the black diamond sand that you get TSC and that stuff sucked I went through a bag in no time the multi purpose sand lasted longer. http://www.google.com/shopping/product/8653924105626083737?lsf=seller:8740,store:91530944 70152751992&prds=oid:12931026018840193401&q=all+pu rpose+sand&hl=en&ei=4ScmVtCLAsXXeLySisgE&lsft=prds id:12931026018840193401,q:SAKRETE+Landscaping+Su pplies+60+lb.+Multi-Purpose+Sand+40100307,lsfq:AA316erd2FSYJFln4KkbCzu t98ROBp76_pbopNvz9ZKabTVVmnjL5_4663CH7utM0esjtJ1B5 t9BjVg0JONC7gCuolVl9WfOOA,hl:en,ei:4ScmVtCLAsXXeLy SisgE,cm_mmc:SEM%7CTHD%7CG%7C0%7CG-Pro-LIA-D22-MaterialsSupply%7C,gclid:CLq5s7P70MgCFU2RHwodejQGR A,gclsrc:aw.ds&lsft=gclid:CLq5s7P70MgCFU2RHwodejQG RA
I don't have access to the sterling sand so I think I'll stick with what I'm using. Thanks for sharing your set up.
My vision is yellow
My blood is white
Oh it's cub fever.
Cub Cadet 124
Old 10-20-2015, 09:12 AM
Never wipe down sandblasted metal, the texture left behind by the sand is rough and will just shred the rag and leave you with a bunch of fuzzies that are about impossible to get rid of.
Old 10-20-2015, 09:39 AM
I use my leaf blower to dry it as soon as I'm done.
Old 10-20-2015, 10:30 AM
Can you prime it if it has the slight rusty haze to it? Or does the rust need to be taken all off?
My vision is yellow
My blood is white
Oh it's cub fever.
Cub Cadet 124
Old 10-20-2015, 01:39 PM
klindstedt klindstedt is offline
The price they quoted me was for the omni paint the high paint was around $450 a gallon. I about shit my pants on that. I will def do a video on the sandblaster to let you guys know how it works. Well I am trying to figure out what type of pain gun combo to do. I have a small pancake tank that i don't think can handle a gun so i looked into harbor freight and found this little set up. http://www.harborfreight.com/high-vo...kit-44677.html If anyone has experience with this or know what type of gun combo to use let me know I'm kinda on the fence right now and hoping to paint soon.
I have the Harbor Freight HVLP Spray Gun Kit #44677, but have not used it to spray any enamel or clear yet. I can say that it did a great job spraying latex stain on my shed (T1-11 siding) and thinned exterior house paint on the soffit and fascia. I intend to try it with auto paint when I do some rust repair on my truck, but the weather is turning too cold to be doing much with that anymore this year. If I remember correctly, there is a YouTube video of a guy spraying a VW bus with this outfit. He seemed to like it fine.
