Old 09-16-2015, 11:47 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Cool 102 broke a rod, look what happened!
Loaded the 102 in the truck to go mow the grass at Mom's old house yesterday. I got unloaded and made 1 lap around the perimeter. All the sudden it sounded like I ran over a stump, then it slowly wound to a stop. Broken rod near the bottom from what I can tell. No window, have a better K301 to go in anyway. I got it loaded with ratchet straps and the starter. By 10am today this is what I had.
My first restoration has officially begun!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 09-16-2015, 11:50 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
WOW!! you didn't waste any time at all. Have fun and keep us posted!!
Jay
Proud owner of the following:
Old 09-17-2015, 12:22 AM
Shrewcub's Avatar
Will do jay! I decided to pull the motor when I got home and it spiraled out of control after only taking 20 minutes to get out. I would have been to this point by 10 last night but decided to wait for daylight before I flipped it to pull the column and drive shaft.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 09-17-2015, 01:10 AM
cubby102's Avatar
cubby102 cubby102 is offline
I still swear that the engine bolts is what holds it all together! The same exact thing happened to mine when my oil pan gasket was leaking. Took the engine out next thing I know it was exploded all over my shed
Old 09-17-2015, 08:43 AM
Have fun with the restore Travis, that should keep you busy for a bit.
Old 09-17-2015, 07:30 PM
That's cool,restore and save for another 30yrs.
Up to 534 and counting...
Old 09-17-2015, 08:49 PM
jaynjeep's Avatar
That's one reason I still really like those early narrow frames.. They are so stinking easy to work on.. True rugged simplicity that works and will still be working 50 more years later!!
Jay
Old 09-18-2015, 10:32 AM
zimm17's Avatar
zimm17 zimm17 is offline
Time for a spray gun, mask, and a few quarts of Case/IH ironguard paint! The only problem after painting mine is that I can't imagine ever cutting grass with it. It'll get dirty!
1973 Cub Cadet 149
2023 John Deere X590
Farmall B sitting in relative's barn
Old 09-20-2015, 01:25 PM
Shrewcub's Avatar
Default Got the grease knocked off.
Did some power washing and drained the rear.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 10-25-2015, 07:20 PM
Shrewcub's Avatar
Well, I have not made much progress on the restoration. I have really been missing my NF, so I pulled the 67 out of the barn and put the "good" K301 in it. Added a 3 point, headlights, changed dashes, and did a half fast steering box rebuild. I put the blade on it today and drove it around the yard. This thing is nice, don't let the po's paint job fool you! I love these NFs!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
