Old 09-04-2015, 07:27 PM
freedhardwoods's Avatar
freedhardwoods freedhardwoods is offline
I changed all the rubber lines on the gas and water today. I flushed the water and put in new antifreeze. I put the original, four solid blade fan on. I haven't been anywhere to get a shroud for it. Idling in the driveway, the temp doesn't get over 170*.
I blew out the line to the tank, refilled it twice, and sucked it dry twice. The problem has to be in the tank. I put a gallon jug of gas on the frame and ran a line to the pump to move it around for now. I will pull the tank later and see what it looks like inside.
I priced a new tank at lmctruck.com. It costs $199.50 there. A friend of mine told me there is someone locally that will internally clean and coat tanks, but didn't know how much they charge. I'm going to check into that.
Old 09-06-2015, 06:50 PM
When I bought this truck, the po said when he tried to put some gas in, it was full. I stopped at a gas station about 4 miles from his place. I couldn't even get a gallon in it. I could hear the gas in the filler neck and it kicked off 3 times. This info is important.
After all the checking I did, it was finally time to siphon the gas out so I could get the tank out.
IT WAS EMPTY!!!!!!
I pulled it up to my gas tank with a straight nozzle and hand pump, and put in close to 20 gallons. I pulled it up to the shop again and walked around to the passenger side.
Gas was dripping out of the cab.
Next I siphoned the gas out like I started to do in the first place.
That was enough "fun" on the truck for Saturday. I went and bought a tiller.
In my defense, a guy at work said the same thing happened to him years ago. He had to dribble gas in to fill it after that.
Old 09-06-2015, 07:20 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
i would replace the tank and fuel sending unit,most likely they are both rusty and there should be a filter on the pick up of the sender which could be plugged from rust. cleaning and lining a rusty tank could be a waste of time and money
Old 09-06-2015, 07:22 PM
sounds like some kids/critters " filled er up"
told you earlier I've taken some pretty interesting things out of the tank Ha,LOL!
LUCK!
Old 09-06-2015, 07:28 PM
If you're meaning the fuel pump, it's on the side of the engine block (large filter too) where all of them should be. I'm guessing there's a screen on the pickup tube.
LUCK!
I'll look when I take it out.
Old 09-06-2015, 11:12 PM
bocephus1991's Avatar
Reading all this is pretty interesting and cool. Makes me wanna get dads old grain truck running. It's a 1957 ford F-600 with a 292 Holley 4bbl 5+2 transmission. Tank behind the seat and a 30gal barrel tank on the side of the frame. 14ft parkhurst grain bed with a hoist.
Brian
Old 09-07-2015, 03:46 AM
That sounds like a neat project.
Old 09-07-2015, 09:02 PM
mudpatrol1's Avatar
Now that would make a GREAT cub hauler
Old 09-07-2015, 09:08 PM
mudpatrol1's Avatar
if it has a gas gauge,there is a sending unit/pickup assembly on the tank where the lines come out of. you should be able to shine a flashlight inside the tank either through it or where the filler neck goes and see how it looks inside. also check the exterior of the tank especially the bottom for rust and leaks at the seams. last tank i had boiled out and repaired for my 64 riviera cost me close to 200 dollars. i had no choice because new replacements dont exist
