I can't get my cub 127 to charge. Had the generator rebuilt and it is getting 13.65 volts from the f terminal on the generator to the battery ground. Ammeter stays on the O. And I have 12.56 volts at the battery. I put a new voltage regulator on too but can't see any sparks from polarizing it. Went over all the grounds I could find and cleaned them. Any ideas? Thanks
IF....the V/R is the correct one, and it is wired correctly, make sure that the V/R is properly grounded. There should be zero ohms resistance between the V/R mounting feet and the battery negative terminal.
http://www.onlycubcadets.net/forum/showthread.php?t=35
Yes everything appears to be wired correctly by looking at schematics. I'm at a loss.
I guess it's possibe to that the new voltage regulator is working either? It's from eBay with the gen terminal underneath it.
Oh and is there anyway to measure voltage from the regulator to the battery to see if maybe a wire is broke in the harness somewhere?
That's what's confusing to me. If you have 13.65 at the s/g A terminal then you should have 13.65 at the battery because of the way it's wired. Do you have it at the F terminal? If you do then it sounds like s/g wired wrong internally or maybe it was rebuilt for CW rotation instead of CCW
I have 13.65 volts from the f terminal to the battery ground. I never used the voltmeter from the a terminal to the battery ground.
Well tonight I ran temp wire from the bat terminal on the voltage regulator to the negative side of the ammeter. The ammeter started working and I have 13.54 volts at the battery. Sound like that's the problem? If so is 14 guage wire big enough for this job? Thanks for all the help
Well I just ran the new wire. Went with 12 gauge. Decided to try polarizing again before starting and what do u know I got the spark this time. Fired it up and its charging perfect. Thanks for the help guys.
