Old 08-24-2015, 05:44 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
Default New BAD habit on the 1772
This past weekend, the 1772 started with a new habit. It seems to be fuel related. When I am starting it, the engine turns over and fires as it should. However within the first few seconds after it starts and I release the key switch from the starter position, the engine begins to misfire drop in rpm and stop. I initially thought I thought the throttle was set too low in speed, so I increased it to 1/2 way. Tried again, the engine reacted the same way. OK, I pushed the throttle to 3/4 and tried again, same results - 2 times. Now, I tried it again at full throttle, sort of the same, ran rough for a few seconds then straightened out. I was able to mow the lawn without a problem. After I finished mowing, I shut it down to clean off the deck. When done it restarted with the same difficulty I was initially having.
I threw new filters and a new fuel pump at it. Same story...... What's left? How does a bad injection pump react?
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
Old 08-24-2015, 06:50 PM
timbo2's Avatar
timbo2 timbo2 is offline
If it's not fuel I would see if the coil is grounding out through a bad wire/connection some where
- Tim
Old 08-24-2015, 06:57 PM
GTKid GTKid is offline
This is the Kubota diesel, not a gas, unless you mean somethin besides the ignition coil
Only a 1282 with ~700 hrs(serial 729357)...
Just red and black and ain't goin back!
Old 08-24-2015, 06:59 PM
timbo2's Avatar
ooops, nope - that's what I meant-sorry
- Tim
Old 08-24-2015, 07:08 PM
sounds like air in the system, did you bleed everything in proper procedure after you replaced the pump?
Got an old perkins 6-354 that likes to pick up air after sitting a spell.
Old 08-25-2015, 12:40 AM
FrankF3's Avatar
Yes, I did bleed it, but you know sometimes a pocket of air can find a good spot to hide. I'll bleed it again and see if it starts better. Thanks, George.
Old 08-25-2015, 08:12 AM
It sounds like you had the problem to start with.
try cracking the lines one @ a time right @ the injectors to maybe bleed off any air.
Hopefully it is that simple, but maybe J. Mech will have some suggestions or others that have more experience with those jay-pan 'injins
Have heard of rebuilding pumps and injectors on those, but not the norm.
Old 08-26-2015, 09:04 AM
FrankF3's Avatar
Hopefully I can get to it tonight. I did not want to do any of this in the pouring rain last night.
Old 08-26-2015, 10:17 AM
JLM78 JLM78 is offline
Is the fuel pump running when the key in the run positon
Old 08-26-2015, 04:24 PM
FrankF3's Avatar
Yes it is, but I swapped it out anyway.
