#41
Thanks for the videos!
#42
Thanks for video and very cool.
What are you going to do about a hood? |
#43
Thanks Guys, I should be getting some attachments to run soon and I'll try and get some video of it mowing and eventually plowing snow!
I'm going to run it without it until I can work out a new location for the fuel tank and muffler. I believe this uses a pressurized fuel system, so I don't think I can use a different tank. |
#44
I might suggest putting a plate of some sort between the mounting nuts and the bottom of the cast (aluminum?) block of the new engine. Otherwise I'd be concerned about the vibration grinding away at the block.
Other than that, it looks GREAT. John
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
#45
"Quiet Line Cub Diesel Repower" with those rubber mounts under the engine!! ![]()
#47
Not sure I'd put rubber under the mounts with a belt drive, how do you keep it tensioned? Think you need to get used to shake rattle and roll.
#49
Very nice job. The video's were great.
1975 CC 1250 CC 1650 1979 Snapper 1855 1973 Wheel horse 12 Auto 1984 Power King 2418 1967 Simplicity Landlord 2012 1968 CC 149 |
#50
Any updates on the build?! This is awesome and I would be very interested in trying to duplicate this. Is this a Kohler diesel?
1965 IH Cub cadet 102 Brinly 10" plow 42" deck Front mount snow blower Front Mount Push Blade Red Spring Aluminium clutch |
