did any 127 cadets come with ported pumps and if not can one be put on or do i need to go with an extra pump hooked to the engine? i am wanting to hydraulics on the lift to go with my sleeve hitch. i may also try the double helper spring to do the job.
They did not come factory... they can be added. Essentially the same pump it will bolt right up but running the lines is going to be cramped because it's a narrow frame but it has been done many times.
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
do you think its worth it or would you suggest an extra engine run pump?
If I were gonna do it is install a ported..much cheaper
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
thanks guys cheaper does sound better.
