Old 06-29-2010, 07:04 PM
young enthusiest's Avatar
Default Pto problems.
Hello all, a customer of mine has a 149 with PTO problems. It will turn on and off, but as soon as the tiller hits hard ground it just slips. The belts are all fine, thePTO just slips, and smells too. I'm sure this has been an issue in the past so could someone post a link that will help? Thanks!
Old 06-29-2010, 07:27 PM
Time for a rebuild. All the info you need is in the service manual.
Old 06-29-2010, 07:36 PM
Which I don't have... Is there an online version?
Old 06-29-2010, 07:58 PM
Butterbean's Avatar
Butterbean Butterbean is offline
The online version is on page 2 of the technical library on this site. I just checked it to make sure the link works.
Charles Rodgers
Clinton, MS
1971 Cub Cadet 126
Serial # 382463
Old 06-29-2010, 08:32 PM
Amigatec's Avatar
Amigatec Amigatec is offline
Some of the 149's used 2 discs in the clutch.
Pat Benner Haskell OK
Old 06-30-2010, 12:47 AM
CMA's129's Avatar
CMA's129 CMA's129 is offline
They all use 1 thick disk now
"Good Dogs Never Live Long Enough!" Casey Angeletti
Old 06-30-2010, 02:51 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
Do you mean springs?
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 06-30-2010, 05:46 PM
Amigatec's Avatar
No it had 2 discs and 2 springs. I guess some of the early ones had 2 discs.
