Old 06-28-2010, 12:46 PM
jpvybes jpvybes is offline
Default LT1045 Reverse safety not working
Hi, I have a 2008 LT1045 and I couldn't be happier with it. However the other day the reverse cutoff safety option stopped working. I always have it on the overide anyway (ie key on Yellow and button pressed) but I noticed that when I have the key on green, the feature that shuts the blades off isn't working. I bought it last year so it's still under warranty but figured I'd mention on here to see if anyone had the same issue. I'm an auto mechanic so I'd fix it myself but since it's under warranty I'll bring it in. It has about 30 hours on it so far and haven't had a problem yet.
Old 06-28-2010, 01:23 PM
Take it in while it's under warranty. Make sure you've mowed with it before you take it in sometimes around here they can be backed up during the summer months. That way your grass will not be to high when you get it back.
Old 06-28-2010, 02:04 PM
Thanks, yes I planned on mowing the lawn Friday morning then loading it up right after that :-)
Old 08-20-2010, 02:17 PM
Ir8tt Ir8tt is offline
There is a switch on the lever where it attaches to the trans with a couple wires. Those wires get broke real easy because they usually get rubbed by a big return spring.
Mine are cut but I dont need the reverse safty.
