Old 07-04-2015, 04:12 PM
ford4150's Avatar
ford4150 ford4150 is offline
Default Coupling failure
Drove my 149 into the garage a couple weeks ago and parked it. Started it up today and after about a minute it started making a racket from the rear of the engine. Sounded like the grass screen rubbing on the housing times 10.
Pulled the tunnel cover and side panels off and started it again. The cooling fan on the driveshaft was rotating in a jerky movement and the sound was still there. Looked a little closer and the problem became obvious.
The 149 has about 20 hours on it since "restoration". New drive shaft, rag joint, coupling, spiral pins, fan and grade 8 bolts everywhere.
You can see in the photo where the coupling separated. Apparently the ring was a press fit on the hub. Don't know if that's correct or an inferior part. It either came from Partstree or one of the other major Cub suppliers; can't remember.
It will soon be welded back together.
Old 07-04-2015, 04:48 PM
Something looks wrong with the part in your pic. If that is the engine end it's not what you should have as an OEM part. If that is or was the coupling for the engine it should look like this. Pic is the part made by Jeff in Pa.
File Type: jpg ad21876f-ecf7-4e9d-808e-d9441be5479c.jpg (17.0 KB, 203 views)
Old 07-04-2015, 05:17 PM
ford4150's Avatar
Yes, engine end.
The driveshaft came from Jeff; the coupling came from one of the vendors.
Old 07-04-2015, 05:40 PM
Originally Posted by ford4150 View Post
Yes, engine end.
Just my 2 cents but I would get a new coupling from Jeff.
Old 07-04-2015, 07:47 PM
I have a couple OEM couplers and they are two piece. I didn't like the design due to the possibility of failure so I make mine one piece.
If you do decide to weld it back together, do your best to make sure it's square or it'll shake the crap out of everything.
Old 07-04-2015, 08:03 PM
I never looked at one close enough till now to notice that they are 2 pieces. Talk about a crappy design. To the OP do yourself a BIG favor and get one from Jeff. Just my 2 cents and I have no personal interest in this what so ever.
Old 07-04-2015, 08:17 PM
For a big manufacturer it works. Stamp out the engine plates and turn 1-3/8" diameter hubs instead of using much more expensive 2-3/4" solid round bar.
Old 07-05-2015, 08:03 AM
I hear ya Jeff, so true, anytime you can reduce machining you save $$
Many times it works, other times not so good.
Just like coring holes and using self tapping screws,-- saves a drill/tap operation,
and many times it works just fine.
Old 07-07-2015, 11:47 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The two piece type is not the I.H. version.
It is some bean counters way of making more profit.
Appears to have been pressed on then silver or lead soldered?
