Old 06-15-2015, 06:52 PM
Pfcsabre Pfcsabre is offline
Default Hydraulics from hydro drive
Hey guys:
I'm new here so i didn't look around to see if this was a thread already if it is i apologize for repeating but i just got a IH cub cadet 1250 hydro drive and i want to put 3pt hitch on the back. I was wondering if i could hook a hydraulic line to the hydrostatic drive pump and still get enough psi to operate a 3pt hitch? I've got a little 12 by 14 foot garden plot that I'll be using it in with a cultivator that i made myself it probably only weighs about 50 pounds with the weight on it
Old 06-15-2015, 09:55 PM
Jumper Jumper is offline
Pfcsabre, Welcome ! I guess my first question is does your 1250 have a manual or hydraulic lift for your mower / blower ?
Old 06-15-2015, 10:34 PM
Agreed, hydraulic lift on a 1250 was an option, if you already have that, then all you need is a three point.
If you don't have a hydraulic lift, it makes things a little more difficult, but still doable. All my hydro Wide Frames have hydraulic lifts and three points, many of them didn't come to me that way.
Go to "Partstree.com" and look up your tractor, there you can find exploded views of the parts you may need.
Old 06-15-2015, 10:36 PM
If your hydro pump has two plugs on top(ported)you are golden, simply add in hydraulic lift. My 129 had the ported pump and I added hydraulic lift. I needed a valve, hnadle, cylinder and lines.
Old 06-16-2015, 10:07 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
I thought all the ported pumps have the desired ports pointing towards the tractor front?
Like this?
Old 06-21-2015, 02:49 PM
I dont have a hydraulic lift for the mower deck but ill check about the pump being ported if it isnt can i put a port on it?
Old 06-21-2015, 03:33 PM
Like this?
That is correct.
You can change the pump to a ported pump.... but you can't turn a non-ported pump into a ported.
Old 06-21-2015, 04:01 PM
Ill have to look to see if i have it i wal also wondering if theres a way to pit a rear pto on it i think i read somewhere i can take the pto off a farmall cub
Old 06-21-2015, 04:44 PM
Berwil's Avatar
Berwil Berwil is offline
........also wondering if theres a way to pit a rear pto on it i think i read somewhere i can take the pto off a farmall cub
Not on a hydro tractor. Even if you had a gear drive, the top shaft is different than an F-cub and wouldn't swap over.
Bill
Old 06-21-2015, 05:16 PM
Alright thank you ill have to find a couple of those 90 degree gearboxes
