Old 06-04-2015, 09:36 PM
johns cubs's Avatar
johns cubs johns cubs is offline
Default PTO bearing removal???
I have the PTO clutch off K301 trying to remove starter/gen pulley off so i can replace keyway in end of crank. Does it just pull off or am i missing something?
Any help would be greatly appreciated!!!
John
Old 06-04-2015, 10:10 PM
Lock ring on the back side needs to be loosened opposite the way the engine turns, about a quarter turn. There is a set screw in it.
Old 06-04-2015, 11:18 PM
johns cubs's Avatar
I got the set screw out but did not try turning lock ring! Figured i was missing something!! Thanks a million Dan. How about the throw out bearing? Any tricks i need to know about that before I tackle that tomorrow?
John
Old 06-05-2015, 04:35 PM
http://ccmanuals.info/pdf/1x4-5%20Service%20Manual.pdf
pg 102-106
Old 06-05-2015, 11:19 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I sometimes wind up putting a 3 jaw puller on to get them off .
Old 06-05-2015, 11:43 PM
timbo2's Avatar
timbo2 timbo2 is offline
If you have a flywheel puller you can try something like this. Not as good as a 3 jaw puller just takes a few tries.
- Tim
