Old 05-13-2015, 05:54 PM
cub2084 cub2084 is offline
Default Quest for more horsepower
I've finally worked all the bugs out of my new to me 2084, which by the way is an awesome machine. I read somewhere that you can change the carburetor and pick up a few HP, but I haven't found a definite answer to what needs to be changed. Any advice on how to pick up a couple ponies would be greatly appreciated.
Old 05-16-2015, 10:41 AM
BassBlaster BassBlaster is offline
Ive read everything from a full carb swap to changing the main jet to removing the throttle stop screw so I dunno what is fact and what isn't. Im curious to know the truth as well as Id like to make my 1864 have 22 HP.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 05-16-2015, 01:46 PM
That's pretty much what I have read. I'm not sure two horsepower would make much of a difference, but I'm willing to do what needs to be done if I knew what it involves.
Old 05-16-2015, 02:29 PM
I don't understand, if you want something with more horsepower, why did you buy something with less?
IIRC, if you want 1 more horsepower, then you need about 1 more cubic inch.
Old 05-16-2015, 02:50 PM
782CC 782CC is offline
The power upgrade is usually referring to the CH18, CH20 & CH22. At least for the CH20 it was determined a main jet change would take it to CH22 specs.
Old 05-16-2015, 03:23 PM
My understanding is the CH18-22 all use the exact same parts except the carb so it has nothing to do with cubic inches.
1994 Cub Cadet 1864
1997 Cub Cadet 2165
Old 05-16-2015, 05:56 PM
gdheck's Avatar
gdheck gdheck is offline
I just looked up some parts for a 1864 and 2284 to compare them. They have:
same block
same rods
same pistons
same crankshaft
same heads
different cam
different carburetor
That's about everything that would change the horsepower. I would be interested to know what the difference is between the cams.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 05-16-2015, 07:57 PM
Tankman's Avatar
Tankman Tankman is offline
One or two more horsepower? Think that'll make any substantial difference?
I wouldn't bother.
Tankman
'95 CCC 1641
Eastern PA
USMC
Old 05-16-2015, 08:17 PM
Funny thing about this horsepower stuff. I've owned Cubs from the 7 hp Original to a 2084 and used them for a lot of details from cutting grass, pulling logs, cars, blowing snow, pushing snow, dirt, etc and I've never run out of power.
Unless the load you're currently applying to the tractor causes the governor to hold the throttle blade wide open, I don't see where changing anything will be of any benefit except bragging rights.
That's not to say that some other owners don't meet my criteria.
As a PS. Didn't some of those Kohlers use coils with an automatic spark advance vs the older engines that had static advance only? That should increase power somewhat.
Old 05-16-2015, 08:42 PM
I agree, two horsepower probably wouldn't be noticed. But I like tinkering and if this would be an easy upgrade I'm up for it. Besides it would give me an excuse to be in the garage with my Cub.
