Old 05-05-2015, 08:54 PM
sgt.porter's Avatar
sgt.porter sgt.porter is offline
Well dang it, I thought I was on to something.
LT1050 w/ 50" deck, 680 Hydro w/ 38" deck, 1450 w/ 50" deck, 109 w/ 38" deck
1A tiller, 42" snow blade (x2), cw-36 snow thrower, H42 snow thrower, #1 cart, 8" Brinly plow, Unk cultivator, Sears rear blade, extra k301, more extra decks and parts than space to put them.
thats normal, the engine has a compression release to help it start.
Old 05-05-2015, 11:02 PM
sgt.porter's Avatar
Thanks for the info. I read up on the compression release (new to me) and managed to track down my feeler gauges. The intake valve is set to .009" clearance and the exhaust is set to .019", both within spec.
As soon as I can get to it, I'll pull the engine shrouds and check the head bolt torque.
Old 05-06-2015, 02:47 AM
Just go ahead and pull the head.
Old 05-06-2015, 08:36 AM
sawdustdad's Avatar
Have you tried starting it with some starting fluid? Just a thought before you pull the head..might reveal a fuel issue... and double check the spark is good.
I'm still betting it's NOT the valves...Beginning to feel better about my bet now...
Old 05-06-2015, 10:55 PM
I'm not convinced.
Old 05-07-2015, 08:24 AM
raytasch raytasch is offline
If not a valve problem, how is the gas spray getting back into the intake? Personally, I would be a bit hesitant to personally bad mouth the seller 'till I knew exactly what the problem actually is. Sh_t sometimes happens.
122 original, well used. Owned since 1972
2182 new to me. Refurbished and gave to my son.
Deere 4300 4WDA HST with FEL
Many old Ford tractors, all gone now
Couple old Ford trucks
Old 05-07-2015, 08:50 AM
johns cubs's Avatar
johns cubs johns cubs is offline
Have you done comp test?
John
Old 05-07-2015, 09:13 AM
Engine has a compression release. Not simple to do a compression test. Easier to pull the head and look.
Old 05-07-2015, 06:23 PM
Frank in Foresthill Frank in Foresthill is offline
Just for S and giggles i just tested the compression on one of my 1650's.
30# after 3 hits on the gauge, wide open throttle. The tractor has been sitting for about a weak and it's about 60* in the shop.
This tractor will lite right off any time.
For what it's worth
Tags
1450, compression, international, k321, starting
