Old 04-17-2015, 05:42 PM
Gijazbo's Avatar
Gijazbo Gijazbo is offline
Default Electrical Gurus HELP!
Alright, So i have been working at this 1450 for about a year (pretty much 3 hours a weekend).
http://www.onlycubcadets.net/forum/s...ghlight=newbie
Yesterday, i finally got it started up after the engine rebuild. Ran it for 15 min and re-tightend the head bolts.
But, heres the problem.
When i tried to start it again my Throttle cable began to glow red hot. So this leads me to believe i have a ground issue. Most likely i got too excited when i was paiting and didnt pay attention to the things that ground through touch.
However, before i go through and ensure all my items are well grounded. how does the engine ground? Should the oil pan and the area where they mount to the frame rail be clean metal? These are iso mounted.
Any help would be appreciated. I hate electrical.
Old 04-17-2015, 05:45 PM
Gijazbo's Avatar
In the link above you can see what is painted.
The starter is mounted bare metal to bare metal. However, i know the Coil is trying to push through too much paint. Got pretty hot as well, but i have good spark.
Old 04-17-2015, 06:43 PM
I like to run a ground straight from the battery to the starter.
Old 04-17-2015, 07:15 PM
raytasch raytasch is offline
Originally Posted by Gijazbo View Post
Alrigh
I don't know how that engine is supposed to be grounded but you are right, it is not grounded except through the throttle cable now. At least the throttle cable is carrying the current to the starter.
122 original, well used. Owned since 1972
2182 new to me. Refurbished and gave to my son.
Deere 4300 4WDA HST with FEL
Many old Ford tractors, all gone now
Couple old Ford trucks
Old 04-17-2015, 07:17 PM
Tim.E's Avatar
Tim.E Tim.E is offline
On an iso mounted engine,you need a ground cable from the engine to the frame.
Cub Cadet 100 "Super" (red) show tractor
Cub Cadet 100 show tractor.
Cub Cadet 100 worker
Cub Cadet 106 refurbished/modified (red/white)
Cub Cadet 128 "refurbished"
Cub Cadet 1450 my dedicated mowing tractor
Tractors awaiting refurbishment:100 with fenders,128,73 with creeper and fenders,106,122,147,126 with creeper.
100 w/pan seat and 3 point hitch
Old 04-17-2015, 07:32 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
there is supposed to be a ground cable going from the engine block to 1 of the bolts that hold the grille to the frame on the right side
Old 04-17-2015, 07:47 PM
Calvins66Cub's Avatar
X's 2!
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 04-17-2015, 08:04 PM
Yep, I believe it goes from one of the starter mount bolts to the right rear grille mount bolt. Sounds to me like it's missing
Old 04-18-2015, 07:04 AM
Gijazbo's Avatar
Thank you for all the help. I will try it out this evening. I understand the grill method, but twith going stright to the battery.... do you just run wire from the mounting bolt to the NEG terminal on the batt?
Old 04-18-2015, 08:20 AM
dvogtvpe's Avatar
from the engine starter bolt to the negative battery post , it does need to be a cable, the same size as the battery cable
