Old 04-11-2015, 09:51 PM
mv7fd mv7fd is offline
Default 1000 carb mounting
I rebuilt the carb on my 1000 and when I went to mount the carb back on I noticed the gasket was a thick gasket but the one I have is all messed up so I need a new one would everything work fine if I put a thin gasket on or even silicone it back on
Old 04-11-2015, 10:24 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
Either gasket works. I've never been real fond of using silicone to bolt the carb to the block. I don't think it holds up that great.
Old 04-11-2015, 10:34 PM
me either but it's going to get rebuilt this year so i'm not to worried about it i just get tired of pushing it in and out. picked up a 782 last night so that'll be my new mowing machine
Old 04-11-2015, 10:53 PM
I gotta go along with both posts, gas is a good solvent for RTV/silly cone,
just use a gasket.
Old 04-12-2015, 12:17 AM
j4c11's Avatar
j4c11 j4c11 is offline
Bought a thin gasket off eBay for a K321 for the exact same reason and it caused issues, the stock bolts were now too long, I had to use 2 or 3 washers on each bolt to make up the thickness. The washers are a PITA to work with when putting the carb on because now there's very little space between the bolt head and the idle screw. Taking the carb off is PITA as well. Finally bought a thick one and that took care of it. My advice, save yourself the hassle, order a thick one, it should be good for another 20 years
Old 04-12-2015, 01:18 AM
Or just use shorter bolts.......
Old 04-12-2015, 09:21 AM
clintsinger clintsinger is offline
If you are going to use something on the gasket RTV silicone is not a great choice, as it does not stand up to fuel etc, when the silicone dissolves it can leave the carb loose and cause all sorts of issues with running. I use here at the shop a good grade of gasket maker, that specifies on the package that it is good for fuel and oil, also use very little just a smear with the tip of your finger is all that is needed and you will be fine, shorter bolts as posted is a good idea.
all the advice posted can be put together and digested and you won't go wrong.
Old 04-12-2015, 10:34 AM
I'm with Don. Carb mountings are a bad place for silicone. I never use it there.
Old 04-12-2015, 10:43 AM
dvogtvpe's Avatar
Kohler only used 1 length bolt to hold the carb on with either gasket. the bolt holes are through holes and are threaded all the way through. so you really needed to do was clean up the threads of the dirt that was in them and all would have been good.
Old 04-12-2015, 11:10 AM
j4c11's Avatar
Good to know. They stopped going in easily about where the thick gasket should have been and I didn't want to risk breaking something by forcing them in, just assumed that's where the hole stops
