Some pics on the hydro seal changes. One of them the new seal is all molded, where as the original one had a stamped steel structure. It didnt seem as good of quality, but at the same time it will likely work just fine. Once installed it gets a washer over the top of it anyway so functionally should be fine.
Did the trick of drilling a small hole through the old seal to then pry it out using pliers. Worked well. |
Then back together
Nice work yeeter
Nice job yeeter. She ought to be good to go for another 25-30 yrs.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
What they said. I see that you didn't replace the PITA one on the other side of the trunion.
Beauty eh! Good job not painting the Hydro fins.
Nice work!! ![]() Make sure to clean the paint off where the filter mounts. I can't tell from the pic if it's paint on tape, or if it's on the metal.... just make sure there is none before mounting the filter.
