Old 03-30-2015, 08:29 PM
Golfnuts's Avatar
Golfnuts Golfnuts is offline
Default Replacing seals on trunnion shaft.
Hello everyone. I have a IH made Cub Cadet 782 that has a seal leaking on the trunnion shaft of the hydro transmission. The seal that is leaking is on the opposite side of the trunnion. I've never replaced one of these seals before and was wondering best way to go about getting seal out. I probably will have to pull the tranny to be able to do the work. Hoping all you have to do is remove the snap ring and washer and somehow pry and pull on the seal and get it out that way. Any ideas would sure be appreciated.
Cub Cadet's I have are (1) IH 782 for pulling Trailer, (1) CCC 1711 GT with 44" Mower (1) CCC 2284 SGT with 60" Mower and (1) CCC 1864 SGT with 50" Mower. Farm tractors I have are 1956 Ford 641 and 2005 John Deere 5320 with Loader.
Old 03-30-2015, 08:56 PM
put a small hole in the seal and screw a wood srew into it and you should be able to pull it out with some vise grips.
Old 03-30-2015, 09:07 PM
Golfnuts's Avatar
Thanks Tim. I assume I will have to pull the transmission to be able to do the work?
Old 03-30-2015, 09:08 PM
ive always done it with the trans out so im not sure it can be done in the tractor.
Old 03-30-2015, 09:21 PM
Golfnuts's Avatar
Tim, I was thinking of drilling a hole in the frame to be able to do what you suggest. I have a 1-1/16" drill to put the hole in frame.
Old 03-30-2015, 09:24 PM
Just take the rear out. Don't be one of those owners who hacks up a machine just to avoid less than 30 min worth of work. It's not like you have to change that seal all the time. This is probably the first time it's ever been changed.
Old 03-30-2015, 09:27 PM
im with Jon on this one, removing the rear end is easy and doesn't take much time.
Old 03-30-2015, 09:30 PM
Ok..... probably longer than 30 minutes.... but like Tim said, it's easy and doesn't take that long.
Old 03-30-2015, 09:41 PM
Golfnuts's Avatar
Ok I will pull the tranny. Thanks Jon and Tim.
Old 03-30-2015, 11:22 PM
Maybe I should add, roll the whole rear end out with hydro attached.
Don't know if you understood that, or at least I do it that way and it is a simple
job, it really isn't that bad.
I'm with the 30 min, ---hour @ most guys if you haven't done it before.
I just pulled one on a 1650 today, wished it was as simple as yours, I have the hydro apart, as it is the seal on the trunion lever side.
We will help if you have questions.
