Old 03-27-2015, 07:05 PM
Pull it off and rebuild it. If you have a screw loose (that sounds wrong) it needs fixin.
Old 03-27-2015, 07:16 PM
swampcadet swampcadet is offline
Does someone sell a rebuild kit for the front pto? Or should I pull it, go through everything and order what I need?
Old 03-27-2015, 08:21 PM
Looking at your photos again the spring is bent (that's why the tab on the top of the photo is sticking out) and w/o the spring it won't work properly.
Judging by the type of spring I see you likely need this http://ccspecialties.org/pics/ptokitb.jpg
PN/ IH-543690-R92 Use 759-3490
I found it here: http://ccspecialties.org/ptocreepers.html
the button you need is P/N- IH-473483-R1 (OEM fiber) a lot of people have gone to the bronze ones, but I've never had an issue with the fiber one.
that page has a whole lot of stuff for mechanical PTOs. Good luck.
Old 03-27-2015, 09:12 PM
Thank you for the link drglinski. My jaw puller didn't fit, so I ordered a new one and will pull the PTO when it comes in. I'll post pics because if something isn't obviously broken, I won't know what to make of it.
Old 03-27-2015, 09:32 PM
you dont need a puller to get the pto off, just take out the 6 set screws and it will come right off, if you need a puller then something is wrong.
Old 03-27-2015, 09:53 PM
Terry C's Avatar
Terry C Terry C is offline
Three regular set screws spaced 120 deg apart remove them and there is three. Pointed ones under them they are holding on the bearing you can't pull the bearing off couse there is a locking collar
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 03-28-2015, 01:09 AM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
You're already mowing. Wow! We still have 30 degree days and frozen ground. Can't wait to do some mowing with my cubs
1961 Original
1962 original w/ fenders and creeper
102
72 w/ fenders and lights
124 w/ sleeve hitch
129 w/ lights
5 mower decks, 2 plow blades, 1snowblower
Old 03-28-2015, 08:31 AM
Go here.....
http://www.cubcadetman.com/cc/how-to...basket-pulley/
Old 03-28-2015, 09:12 AM
red211's Avatar
red211 red211 is offline
I mowed for the first time yesterday. Needed it on Monday, sorry for the high jack.
73 149, 73 109, 71 128 with sleeve hitch, decks for all with a 44C on the 149 as the daily mower. front blade and IH rock rake
Old 03-28-2015, 06:05 PM
Been soaking the allens in kroil for 12 hours. The first one (exterior and interior) came out so easy, but the second two ruined all 4 of the 1/8" allens I had on hand. Of course, both stores I went to didn't have any 1/8 singles in stock. So I ordered 25 from Amazon and will keep soaking in kroil until they come in. I really hope I don't have to drill them out.
