Old 03-24-2015, 05:23 PM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Default 1863 check valve leak.
I've got my 1863 at my sons house. Today I went over and used it to mow his grass. When I finished I started to park it where it was and saw a golf ball oil spot. I removed the tunnel cover and looks like one of the check valves is leaking. I know I need to remove them and have them rebuilt but does it need to be done before I use it again or can I use it a few more times until I get the 1641 ready to swap out with it? About what is the turn around time on the valves sent to Mechtec?
Cannon
Old 03-24-2015, 06:13 PM
Depends on how bad they are leaking. Turn around time seems to be 7-10 days from my experience.
Old 03-24-2015, 09:59 PM
The 1863 has a Hydro-Gear pump and doesn't have the valves like a Sunstrand pump does. Got any pics? Maybe you have a broke line or leaking external pressure relief that the HG pump uses.
Old 03-25-2015, 04:04 AM
Cannon51's Avatar
Well that's embarrassing. I guess I need to get the fender pan off so I can see whats going on. Thanks
Cannon
Old 03-25-2015, 07:17 AM
I should have caught that one, Oak is correct about it having a Hydro Gear pump. I seem to recall Houtz saying that some did have Sundstrand pumps. Guess you need to do some more digging.
