Old 06-06-2010, 04:48 PM
labrati labrati is offline
top-sider.. I use it to change the oil in my car.. works in the cub too...
Old 06-06-2010, 05:41 PM
Amigatec's Avatar
Amigatec Amigatec is offline
What is a "Top-Sider"?
Pat Benner Haskell OK
Old 06-06-2010, 07:13 PM
ajgross ajgross is offline
Inactive Member
You could look into a Pella oil extractor. It will suck the oil out through the dipstick tube. Strangly enough, it really does a good job of removing all the oil.
AJ
Old 06-06-2010, 07:34 PM
Amigatec-
How exactly is that going to work? You're still going to get a bunch everywhere between taking out the oil plug and putting that thing on there.
Old 06-06-2010, 07:43 PM
Amigatec's Avatar
It will be a bit ticky, but you have to use 2 hands and hold it until the oil is drained. I may work with it some more and improve on it.
Old 06-06-2010, 07:52 PM
AJ
Just watched the video looks like it did a pretty good job! Which model do you have?
Old 06-06-2010, 08:41 PM
Mountain Heritage's Avatar
I am confused? I removed the deck from my 982 (which is VERY simple) to change the oil. I leave the mule drive and sub-frame on for the deck with very little issues. I slide the large square oil drip pan under the tractor, loosen the drain plug with the wratchet & socket, then take it out the rest of the way with my hands. Drain the block, then slide the pan over slightly and remove the oil filter and let the two drain out completely (as much as I can get out of it). When finished I slide the pan out with the old oil in, take a rag and wipe off the little dribble down the side of the frame from where the oil filter is. Then reach up underneath and screw in the drain plug finger tight, grab the socket and wratchet and tighten it up. Grab the rage next and wipe off the the small piece of the frame and the cross bar of the sub-frame. TOTAL amount of oil I wipe off the tractor....maybe 2 tables spoons? I am sorry...I don't see what the big problem is? At least, there isn't one on the 82 series.
Old 06-06-2010, 09:01 PM
Amigatec's Avatar
I don't having to remove the deck everytime.
Old 06-06-2010, 09:20 PM
Inactive Member
Methos I don't have one, but a good friend of mine does. He uses his quite a bit. I think he has the 650 model.
AJ
Old 06-06-2010, 10:04 PM
Default topsider
This is what they use on my MB (commercial version).. figure if it's good enough for them it's good enough for everything I drive...
We've had a 12v model for our big boat for years... never even dawned on me to use it in anything else till I walked (years ago) into the shop and noted thats how they were changing the oil... I asked the mechanic (who was changing it on a gelandewagen 550) if that was standard.. he said absolutely.. they didn't drain the pan unless something else was at issue...I asked on all of them, he said every single MB.. this was factory approved..
on my MB the oil filter is actually a pretty crazy contraption.. I do get some oil on my hands changing out the 5 O rings and sliding the filter on.. but the pump makes extracting the oil into a recycling container very, very simple..and very, very clean..
http://www.northerntool.com/shop/too..._390306_390306
http://lifehacker.com/189493/diy-topsider-oil-changer
