Old 03-14-2015, 10:43 PM
Berwil's Avatar
Berwil Berwil is offline
I probably did the pin also, it's been a few years, don't quite recall. If it was worn, I would have built it up and ground it round.
Bill
Old 03-15-2015, 08:25 AM
john hall's Avatar
I'm not saying you shouldn't, however, aren't those plates hardened to begin with? Welding on them may serve to anneal them or cause the area right where it is welded to become so hard it is brittle. The reason I believe they are through hardened (as opposed to case-hardened) is that I broke one on my 2072, it was bent(we think from the factory to be honest). We tried to straighten it---didn't take much effort and it broke. Looking at the pics, I think I'm talking about the same plates. If I did weld them, I'd keep them as cool as possible, use no more heat than needed, weld one up and then weld the other after the first cools.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
