Old 01-27-2015, 10:00 AM
Congratulations on your 129.
Old 01-27-2015, 06:16 PM
kyleb179 kyleb179 is offline
a little progress today due to heavy snow removal. i scraped a whole bunch of crap out from around the hydro and rear end. got 2 shovel full of stuff. i agree with you saturn, i think it is also. a few questions i have:
first, in this picture, what does this push button do? infront of the rockshaft. not really sure, its hooked into the wiring harness.
second, is this a sunstrand hydro? if so, where can i get this rear seal if it is indeed leaking? does this remove from the tractor just by removing the 2 bolts in the frame, the hydro line underneath and the driveshaft?
thanks guys
Old 01-27-2015, 06:31 PM
sawdustdad's Avatar
That pushbutton is the clutch interlock switch. Supposed to keep you from starting the engine without having the brake pedal depressed.
All the hydros are sunstrand units. The gaskets (and other parts) are available from forum sponsors, partstree.com and numerous other sources.
The hydo unit comes off the rear end by removal of the drive shaft, the suction pipe underneath, the hydro lift lines, and 4 bolts that go through the unit into the rear end.
Old 01-27-2015, 07:43 PM
okay cool thanks for the info. now i need it to not be freezing so i can go powerwash! lol
EDIT::: the pulley that is on the flywheel side of the driveshaft, is that for a hydraulic pump for hydro lift?
Old 01-27-2015, 10:06 PM
You could, but that style of lift is for a Narrow Frame tractor and was never used on a Wide Frame.
The hydraulic lift on a Wide Frame uses a ported transmission and all the rest of the parts fit in under the tunnel cover.
Old 01-28-2015, 11:29 AM
gotchya. wasn't looking to do it, just curious if that is what it was for.
i just noticed the headlights are stickers, can i add lights from another rig to this one?
Old 01-28-2015, 06:04 PM
Has anyone ever made a NF hydro pump work on a wide frame gear drive? I know that they made an E lift for the wide frames but they seem very rare and expensive.
Old 01-28-2015, 06:06 PM
Yes you can find light panels complete, extra harness for them and switch from our sponsors or put an ad in the wanted section
Old 01-28-2015, 08:12 PM
As it happens... There s a picture of one, in my pictures thing, that I did on a 128.
Old 01-28-2015, 09:38 PM
By far the best one I have ever seen re-worked to a WF. Neat job on the setup and definitely worth looking at!!!
