Old 05-25-2010, 11:01 AM
tinkerin tim tinkerin tim is offline
Smile Has anybody used Zero Rust
Hi everyone,
I'm a newcomer,but as someone said I've been lurking around. My wife and I were at a friends place about 100 miles away. I hung out while the wife went to a bridal shower. Saw this old cub cadet behind the garage and asked what his plans were for the tractor. "why, you want it?" how much you want for it? "i should pay you to get it out of here".
I didn' know anything about old cubs. Then I started reading this forum. Couldn't get back there with a trailer fast enough. Result: came home with a 1974 149. It never had a mower, only a snowblower. Must be low hours. It took weeks of Kroil to free up cables,levers, etc. Pulled engine to get acorns and stuff out of flywheel. to keep this from becoming a book, I'm planning a total strip down and repainting. These are awesome little machines. I'm hooked.
Has anyone here used Zero Rust? From the literature it looks great. Another question concerns painting the engine head and cylinder. Will a high temp paint last?
More questions to follow, I'm sure.
Thanks in advance for your input.
p.s. This tractor belonged to my buddie's dad. I had many a beer with this great old guy. Makes this huge project extra special. I figure $300-500 and I'll have a tractor that should last forever indoors.
Old 05-25-2010, 11:40 AM
Welcome to the forum!
Do not paint the head; it will not dissipate heat as well if it is painted.
Old 05-25-2010, 12:37 PM
Congrats on your 149! After you are done with it, you'll have many years of service.
Old 05-25-2010, 12:48 PM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 05-25-2010, 01:40 PM
Old 05-26-2010, 09:05 PM
Default What about the fins on the cylinder
Matt,
Does that go for the fins on the cylinder too? I thought I should at least put some kind of rust converter. Don't they get painted originally?
Thanks
tim
Old 05-26-2010, 09:20 PM
The cylinder would have been painted, but not the head. I'd also recommend leaving the oil pan bare if it is an aluminum one. That'll keep your oil temp a bit lower.
I guess I'd clean and paint the cylinder. The paint is going to burn off and it'll eventually rust again. Bare iron would be best for conducting heat, but it will rust. I doubt the rust is any better at heat transfer than paint, so you might as well keep it from rusting away.
Old 05-26-2010, 09:55 PM
cledford cledford is offline
I've just come across a spray paint that is a "rust converter" it claims. Spray on and it converts existing rust to rust oxide. Not sure if it can be used in high heat areas - got it for a rusty shovel...
Have also heard of "naval jelly" wich converts rust to oxide. Not sure how you'd get it on/off - but someone told me that once it converts the rust to "rust oxide" that the part wouldn't rust again.
Any thoughts?
-Calvin
Old 05-26-2010, 10:33 PM
"Rust Oxide" sounds fishy. Rust is Iron Oxide. The part will rust again; it's not going to change the properties of the steel.
Old 05-27-2010, 08:12 AM
norvegicus's Avatar
norvegicus norvegicus is offline
Zero Rust is my favorite rust proofing paint. Good stuff and easy to use.
