Old 01-14-2015, 09:22 AM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Default 2182 fuel shut off valves
I'm posting this to hopefully help others. I tried to buy replacement fuel shutoff valves for my 2182 and was told they were no longer available. I found these from another model and they should work for a replacement. Hopefully this helps someone.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 01-14-2015, 10:39 AM
They look the same except for the screen. What are they supposed to go to? Were yours so bad that you couldn't clean them?
Old 01-14-2015, 10:54 AM
Not bad for 11.00.nice find.
Old 01-14-2015, 11:42 AM
Better for $9.21
Displaying search results for '951-0171' in Cub Cadet
Part # Outdated Description Price Where Used
1747184 ! USE 951-0171 VALVE-SHUT OFF $9.21
751-3007 ! USE 951-0171 VALVE-SHUT OFF $9.21
GW-1747184 ! USE 951-0171 VALVE-SHUT OFF $9.21
GW-1751477 ! USE 951-0171 VALVE-SHUT OFF $9.21
GW-B1747184 ! USE 951-0171 VALVE-SHUT OFF $9.21
IH-135354-C1 ! USE 951-0171 VALVE-SHUT OFF $9.21
Old 01-14-2015, 11:51 AM
I'm not sure what model they are from. I just bought them just incase mine started to leak after cleaning them and actually using them. My 2182 has sat outside for some time before I got it and they didn't look good but wound up cleaning up fine. Can't hurt to have spairs just incase. I paid $11.91
882- 50c Mower Deck
Case 646 FEL
Case 446
Old 01-14-2015, 02:53 PM
PaulF PaulF is offline
That looks exactly like the one installed on my 782D...screen and knob look identical...thanks for sharing the info
Paul F
Infantry Veteran
Original...100/123/147 custom...149 FEL...782D...1282...1864...2182G
Old 01-14-2015, 06:22 PM
Kinda looks like the push/pull valve off a quiet line would also work.
