Old 01-06-2015, 11:57 PM
Kind of late now I suppose...but, did you happen to check the oil before you started it?
Old 01-06-2015, 11:58 PM
if its turning over and no air is coming from the spark plug hole then its got to be a broken connecting rod, with any kind of luck it didnt hurt the block to the point it cant be rebuilt. that said if its over your head theres plenty of guys on the forum that you can send the engine to for rebuilding. good luck
Old 01-07-2015, 12:35 AM
cub cadet 72 guy's Avatar
cub cadet 72 guy cub cadet 72 guy is offline
Sounds like you threw the connecting rod
Old 01-07-2015, 08:50 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
The good news is................if there is not a big puddle of oil on garage floor and no holes in the block, maybe it will be an easier and less expensive fix.
Old 01-07-2015, 08:55 AM
Another vote for the engine needing rebuild.
Old 01-07-2015, 12:34 PM
TheSaturnV's Avatar
Rebuild that Kohler and get another 30 years out of that bad boy. Whatever you spend will be less than a new throw-away sheet metal "tractor" from Lowe's Depot.
Old 01-07-2015, 01:04 PM
Sorry to hear about your engine problems, but you can't argue with TheSaturnV's logic. Once the engine is rebuilt, anything else that could be or go wrong with the tractor can be be repaired/replaced for cheap and you'll have a tractor that will give you many more years of faithful service.
Old 01-07-2015, 01:22 PM
Not sure but I think J-Mech has an exchange program if your in a rush it may be the way to go.
Old 01-07-2015, 02:36 PM
20 years ago I bought a 129 that had a broken rod. I replaced the rod, pan gasket and head gasket. That's all. Been running great since then. No overhaul. Not even a new spark plug.
Old 01-07-2015, 03:20 PM
Your just lucky.
