Old 11-24-2014, 05:39 PM
ford4150's Avatar
ford4150 ford4150 is offline
Hydro cork gasket procedure with pictures is here:
http://cubfaq.com/corkgasket.html
Old 11-24-2014, 05:58 PM
PaulS's Avatar
PaulS PaulS is offline
Most hydro leaks can be a problem to find. The fan will blow the leakage all over the rear end so much so that finding the actual leak can be a problem. On our 2072 we thought the leak was coming from several places till we actually found the cork gasket to be the actual problem. When looking for a leak be sure everything on the rear is clean first. If you have to start the engine to pressurize the system keep the rpms low like idle and then shut it off and with a good light start looking for that leak.
Old 11-24-2014, 06:03 PM
If you can get everything cleaned off good and dry, squirt talcum powder all over everything with a syringe bulb. then the oil trail in the powder should lead you right to the leak.
http://www.chrysler300club.com/how/leak/leak.html
Old 11-26-2014, 04:40 AM
cdlong's Avatar
cdlong cdlong is offline
I actually got under mine and used 12 gauge shotgun cleaning patches, a pocket flat bladed screwdriver and a pick set. After washing the hydro and charge pump, I sprayed the patches with carb cleaner and worked them around the nooks and crannies until I could see where the oil was coming from.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
