Old 11-15-2014, 01:52 PM
garnold's Avatar
garnold garnold is offline
Default Installing new feet on blade
I've never used or installed a dozer blade before. The one I have had no shoes so I bought new ones. Question, how far does these shoes extend down? Should the blade be riding on these ?
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 11-15-2014, 04:11 PM
IMO that's why the skid shoes are there, so the blade wears on them and not the rest of the pieces (like the wear strip, etc). I keep my blade wear strip off the ground about 1/4" at max. Also, make sure they are set even so your blade is level.
Old 11-16-2014, 12:13 AM
Berwil's Avatar
Berwil Berwil is offline
I set mine so it rides on the shoes. Easiest way is to park the tractor on a flat surface and put some 1/4" steel or plywood under the blade and then unscrew the shoes and lock them down. If you have a nice new smooth driveway you could get away with 1/8" gap.
Bill
Old 11-16-2014, 01:01 AM
jimbob200521's Avatar
I don't use wear shoes on my blade. I replaced my wear edge with a thick rubber matting that wears at maybe a tenth of the rate the steel edge does, so no need for them.
BUT that's not what you asked They are supposed to be set just a hair lower than your wear edge so they wear before it does
-Ryan
Old 11-16-2014, 01:17 AM
garnold's Avatar
Thanks everyone. This is what I needed to know
73 WIP
75 WIP
