Old 05-16-2010, 11:38 PM
lowlyfzlucky's Avatar
lowlyfzlucky lowlyfzlucky is offline
Default 1450 axle help
I have a Cub 1450. The front axle is moving to the right when steering the tractor. I just bought this and am working on restoring it. My question is if the front frame might be bent where the axle pin goes in. Mine has a slight bow in it, and I'm wondering if it should be perfectly straight across. Anyone know?
Thanks
Old 05-16-2010, 11:42 PM
The C-channel that the axle rides in often gets spread apart by the axle moving around. Remove the front axle, and then squeeze it back together with a 3/4" bolt and nut through the axle pivot in the frame. You might have to try it a few times until the axle fits nicely in the frame with no slop.
Old 05-16-2010, 11:49 PM
superduty5.9's Avatar
superduty5.9 superduty5.9 is offline
This might help!http://www.onlycubcadets.net/forum/s...ead.php?t=1372
Old 05-17-2010, 12:16 AM
Old 05-17-2010, 12:30 AM
Thanks for the help guys. I'll try closing the gap in the frame channel.
